0 members (), 85 guests, and 0 robots.
Topics128,115
Posts1,056,291
Members48,439
#793713 10/30/2011 8:24 PM
I have six cars in an unheated garage, all enclosed and not heated..Up here in Idaho, it gets down to 10 above, should I remove batts to a slightly warm garage..and battery tend them, or loosen the neg cables and be done with it?
1936 Chevy Suburban Carryall
1941 Chevy Woodie with Cantrell body
1936 Low Cab Chevy Pickup
1941 Spec Deluxe Chevy Coupe.
1953 Pontiac Catalina hardtop
More pix on Flickr
why not put keep them in the vehicles and put a tender on them?
Brian
Slinger, WI
'37 3/4 ton (grandpa)
'11 3/4 ton (grandson)
http://picasaweb.google.com/lh/photo/4xMv20nIhYF_AUPgEkRiFQ?feat=directlink
We take the batteries out of our stuff in the winter and bring them into the shop. I have a battery tender that I put on for a week and then move it to another battery. In the spring I check them with a load tester to make sure the battery has a full charge in and then install it. Been doing this for years with good success.
I have just left my 6v Optima batteries in the vehicles the past three years. No problems starting in the Spring (it sometimes gets to 20 below here).
However, using a battery tender in the truck, or on the battery in a heated or unheated garage, or bringing the battery into a warm room cannot hurt and might even help the battery life.
I open the disconnect on my battery and hook up a battery tender that uses the "float" technology. Temperatures of -25 F are not unusual where we live. I don't run my truck in the cold weather so it sits that way until spring.
1951 1 Ton Completed
A battery will slowly self-discharge unless the engine is started periodically and run for a few minutes, or some sort of trickle charger is used to maintain it. Discharged batteries can freeze, but it's almost impossible to freeze a fully-charged one. The best possible situation would be to store them in an area that does not go below freezing, and use a trickle charger or a battery maintainer to keep them charged.
Even if it does not freeze, a discharged battery that stays that way for several weeks will develop hard crystals of lead sulfate on the plates, and it will be extremely difficult to recharge. Keeping a battery fully charged at all times is the best way to assure it has a long, useful lifespan. Rule #2 is keep it bolted down- - - -bouncing around destroys a battery in a hurry.
