0 members (), 78 guests, and 12 robots.
Topics128,021
Posts1,055,355
Members48,420
#79369 06/29/2007 3:41 AM
Anyone running an air over leaf setup with some leaves removed on their AD truck? Just wondering how good the setup works? Would like to hear comments good or bad. Thanks!
I would worry about doing this in the front. When you remove leaves, the axle becomes more likely to rotate under braking, which makes your alignment go funny and you may have trouble steering. It isn't a problem in the back as long as you keep the torque tube.
Paint & Body Shop moderator
