| | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | I'm thinking I want to upgrade to a 261 for my truck and have read posts here telling what trucks they came in but my question is how do I positively ID a 261 cu. in. motor? I'd like to know what I'm doing before I go shopping.
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Check out Patricks Antique Trucks web catalog. He gives the info you need to spot that 261. Inliners International also has good info on 261's. Good luck. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Hey sleeve, Drew's link shows the captains bars on the block. That's what I would look for. Up here in Canada, the 261 came in Pontiacs from 1954 - 1962, I believe. That's where mine came out of. | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | I think the casting number on the block, not the head, would be useful in verifying a 261. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The Captain's bar on the block is not a definitive ID of a 261 engine (1954 truck 235s had the captain bars, too). Check Jim Carter's link, above.
The head and block casting codes and the engine serial number (ID) are the best ways to ID a 261.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Tim, I have worked on a lot of Chevs, and I have never seen Captains bars on any 54 235 engines. I have seen that all 1953 Power Glide engines had them though. I believe that in 53 the Captains bars were used at the factory to make a quick and easy distinguish between the splash 235, used in stick cars, from the full pressure engine, used with the Power Glide. Then in 1954 the Captains bars were used on the 261 to make an quick and easy distinction between the 261 and the 235.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I'll check my 235 truck engines tomorrow, Dave.
I have been quoting for years Jim Carter's article about 54 engines having the bars (above the starter) but I have never confirmed it on my engines (I have four 1954 235s: three Thriftmasters and, I think, one Loadmaster).
"Watch for the “Captain’s Bars!” The 261 has two pairs of parallel raised 3/4 inch long bars cast in the block. This is not seen on a 235 except 1954. One pair is above the starter and the second pair is at the top middle of the left side of the block very close to the head. See photos below. The one exception is the early 261 produced in 1954 to mid 1955. It has only one “Captain Bar” above the starter but keeps the pair on the left side."
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Here is an example of a March 5 1953 235 with Captains Bars. LINK
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2011 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2011 Posts: 43 | My 1954 261 does not have any captains bars over the starter area Josh | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Hey Josh, Chev has definitely done some strange things over the years. I have seen a number of 54 261 with the captains bars, and no 235s. I wonder if you can give us the casting date above the starter and the serial number stamped next to the distributor. I'm wonder if you have a replacement engine.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2011 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2011 Posts: 43 | No numbers on pad and here is a pic of the #s more pics Josh
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Very interesting, Josh. As you said, 261 block casting code and no bars.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Here is an example of a March 5 1953 235 with Captains Bars. LINK Dave, That Picasa link did not work for me. "Sorry, that page was not found." None of my four 1954 235 blocks have bars above/behind the starter. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Josh, are the 1/4" bolts for the pan in a straight line on both sides, or do they curve towards the center on the distributor side.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I have a 1953 235 powerglide engine. It does have the captains bars above the starter.
Kurt | | | | | Joined: Jun 2011 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2011 Posts: 43 | The oil pan bolts are in line no bend in pan side it also used the longer oil pump Josh | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Josh, I can't explain your engine. I thought the Aug 17 4 might be 1964 instead of 54 and be a replacement engine. Replacement engines I have seen used the 1955-62 pan design, ie; curved bolt pattern.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | Here is an example of a March 5 1953 235 with Captains Bars. LINKLink not working for me either. Both of my 261's a '54 and a '58 have the bars in both locations.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Feb 2012 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 84 | Got a 53 Powerglide 235 on the stand in the shop, got both pairs of "Captians bars" on it. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Canadian Pontiac 261’s started in 1955 and came in a number of different shades of green. Later ones have the pin boss cast in them but it is not machined.To my knowledge American ones are only alpine green or yellow? Examples here.(scroll down)
1952 1300 Canadian 1/2 ton restomod You Tube | | |
