9 members (Hanks custodian, Hotrod Lincoln, Ponchogl, Otto Skorzeny, Bill Hanlon, Charles in CA, 48ed56pam, Bill Marlow, frogfarmer),
177
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,071 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 63 | I've looked and can't tell which it is. Block numbers are Cast #3837004 Ser. #F60511, head cast. # is 3535913, I think their out of a truck. Block has boss holes for a car mount and the front plate has the holes in it. Block & head have remnants of light green paint.
Also, did the main bearings change (dimple on block half) during this year or later?
'53 BelAir 261 3spd/OD 4dr '54 3100 235 3spd '79 C30 with a '51 235-'57Bellhousing-'67SM420-14bolt dually '89 V3500 350/465/205 SRW CC One Chevy just isn't enough.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Mains changed in mid 55 Going by the Serial number it looks like a 1960 engine. If the "I" you posted is a J,at the end, it is a truck engine, but after 1958 there are no differences in car and truck blocks anyways. They are all drilled for hydraulic lifters.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2010 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 63 | Thanks Dave. 1960? I thought, could likely be wrong, that 3837004 went from 1955-1957? A 1960 would be a bonus. Nope it's a 1 at the end, I'll keep the J part in memory though. This block has the "milk can" mechanical lifters, any for-see-able issues with that?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You can confirm the date by looking at the casting date above the starter.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Inliners does show 3837004 as 1955-57, but they may be wrong. Is your engine setup for center side mounts?
Can you post a pic of your engine?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2010 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 63 | No on the center sides, just the forwards and fronts. It's an engine for sale so phone pics are what I got. I forgot to get the date of the block, but I could get it. I was curious if there were differences between truck and car blocks, in 1955, other than trucks got Mech. lifters and front mounted? Is it possible to put hydraulic lifters in mech. truck blocks before '58 as long as the cam is appropriate?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Up through 1955 the only 235s with hydraulic lifters were car 235s used with a Powerglide transmission.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If it does not have center side mounts it is pre 1958. Before 1958 only engines that had Power Glide transmissions, had hydraulic lifters. Stick cars and truck engines are not drilled to supply oil to hydraulic lifters. Starting in 1958 all 235s are drilled for hydraulic lifters, whether they were used or not. This was done as part of the new oiling system for the rockers. See Fig.#15 in this LINK
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Tim, in looking in the parts book I would agree, In 1956 and later, all pass had hydraulic lifters. So 1956-62 pass engines would all be drilled for hydraulic lifters, trucks would not be drilled until 1958, even though they did not use them.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2010 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 63 | That's what I've gathered. There was only one I6 engine used in cars from '56-'62 and they had hydraulic lifters. Then in '58-'62 all I6's were drilled. I just figured it out, the "drilled" wasn't a bore size it was the horizontal galley oiling the lifters around their annulus. Thanks Guys
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | There was only one I6 engine used in cars from '56-'62 and they had hydraulic lifters. I'm not an engine guru but I beg to differ on that statement. My 261 is a car engine from '58. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | But is it a Chev? and I don't mean in a Chev:)
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In Canada the 261 was also used in a Pontiac car. It had hydraulic lifters. All truck 261 engines in the USA (and, I think in Canada) had mechanical lifters.
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | The Canadian Pontiacs were a different animal. They had Chevrolet power trains for many, many years. | | |
