4 members (JeffA, dt235sd, klhansen, UtahYork), 62 guests, and 3 robots.
Topics128,180
Posts1,057,160
Members48,464
I bought a 1948 Chevy 1/2 Ton Pickup...it has a 1955 chevy engine in it.
The Kentucky title has a VIN of - FBA450934
and the engine is 1955 i think since number on it is - 0550236F255
Cowl Tag on Inner Door is:
Serial # - 9FPH6586
Mfg. Date August 1948
Model 1/2 Ton
Wheelbase 116 inches
Plant Norwood, Ohio
I live in Ohio and bought the truck from Kentucky.
How do i go about getting them to title the truck...since i do not have the matching original engine with VIN?
1948 Chevy 5 Window 1/2 Short Bed
1969 Dodge Coronet SUPER BEE 383 Ramcharger
1949 Bentley Mark VI Standard Saloon
http://imageshack.us/photo/my-images/695/dsc04398mm.jpg/
Hi,
I live in Ohio also and had the same problem when I bought my 51. It was registerd in NY with the engine number and I wanted to title it in OH with the VIN. Had to take it to a Ohio Highway Patrol inspection facility and they put it on a lift and checked it over and then gave me a form with the VIN number on it and I was able to take it to the BMV and register it. Check with your local BMV for the nearest inspection facility. I had to wait a couple of weeks to get an appointment.
Hope this helps.
Chris
Chris did they find a VIN somewhere on the truck? How did they verify the VIN to get you cleared?
Originally Posted by kenneycj
Hi,
Hope this helps.
Chris
I think, but not sure on this, that there is a number on the frame too that matches the VIN I think that is what they were looking for. I also think they were checking for any parts that had been put on that may have been stolen. Once it came back ok they just signed off on the VIN that was on the door jamb. A friend of mine had to go through the same thing with a replica of a Cobra that he built before they assinged it a VIN.
I also found out the hard way that I could have driven the truck to the inspection station even though my 30 day tag had expired. All I had to do was call the inspection station and they would have sent me a letter saying it was ok to drive to the inspection and back--would have saved me $$ on a trailer rental.
Hope this helps.
Chris
From what i have heard there is no VIN number on the body or frame anywhere??? And the Cowl? Tag of the driverside door frame just has - (FP-H 6586)
Hope i could find the VIN on the body or frame somewhere....anyone know if there is one?
Hope this helps.
Chris
I think your tag is not original either. Check with your local DMV as stated. They will have a solution for you. If you bought this on ebay, they may also have a solution with their guarantee if the time line is not past. Put your body tag number HERE Double check before you go to the DMV.
There will not be a vin number stamped on the frame for this year. As stated your truck was registered with the original engine, this was common practice by many DMV'S.
Your tag should be attached with either clutch head screws or philip head screws. replacement tags are available from vendors such as Jim Carter
plugged in tag and came up with this
Serial # - 9FPH6586
Model 1/2 Ton
Plant Norwood, Ohio
Can't i just use the Cowl Tag as the VIN of the truck and them change my title accordingly?
It appears that you do have the correct tag, I used the numbers you provided and they came up different.
Quote
"Tag of the driverside door frame just has - (FP-H 6586)"
Be prepared when you go into the DMV. Explain that you want to register the truck using the body tag on the door pillar. Explain that the original engine has been removed and the new engine does not have the same numbers as the registration. Take any info you have with you.
