0 members (),
91
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 89 | Getting ready to re wire my 1946 1/2 and need some advise on which size of wiring loom to buy. I know that I need a thicker size wiring loom coming out of the fire wall and than probably another size to the front lights and the back lights. What 2 sizes fit the best and how many feet of each size do I need ? Any advise or suggestions are appreciated. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'd suggest buying a harness. A homemade harness all done in one or two colors is going to be a devil to troubleshoot. Since you have obviously no experience with wiring, expect some troubleshooting to be required. | | | | | Joined: Mar 2005 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 89 | I already have a EZ Wiring Harness but want to wrap the wires in a loom but I am undecided on which size I will need and was wondering if anyone recently had used wiring loom on their truck. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | just wrapped up rewiring my 46 one ton with a ez wire harness.I used 3/4 " for the wires going through the driver side firewall.1/2" for the rear lights,and some 3/8" for some of the guage and coil wires.As far as how much, i would measure your runs and add about 20%.I was happy with the quality of the harness for the price,about half of painless and most others.the printing on the wires every 5" is a big help.Good luck,take your time and if you don,t have one get a good soldering iron and lots of assorted heat shrink tubing the kind with adhesive liner not the cheap crap. | | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | I used similar sizes with the crap I bought from the Irish FLAPS, one got within a few fractions of an inch of the valve cover and warped badly. If you know of a place that has higher grade material, use it. This stuff was paper thin.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
