6 members (50Chevy3100, SmalltownTRKGuy, LAJones48, mick53, 55shaker, dt235sd), 113 guests, and 2 robots.
Topics128,092
Posts1,056,455
Members48,443
The beltline on the back of my cab is rusted out in several places. These cabs were built in multiple pieces and each has a "c" shape overlap that becomes the beltline. The roof piece overlaps on top of the back piece of the cab.
When I patch the cab does it still need to be two overlapping pieces so it can flex or move? Why can't I fabricate a beltline bump and weld in as a one piece repair?
Clear as mud? Thanks!!
1946 Chevy Half Ton
('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS)
1976 Margay Panther X, MC91B
I didn't have the rust issues you have, so was able to paint without much repair. Truck has been painted for over 5 years now and there are no signs of belt line moving or slipping within itself, so I don't know how much movement really happens in that joint ?
1940 Chevy KC 1/2-Ton
The joint is there due (educated guess not original knowledge) to having to form the sheet metal in several pieces. I see no reason you couldn't make the patch as you described. If you're a good welder and body man, why not go ahead and seam weld the whole joint? I made sure they put a good fill of seam sealer on mine before paint.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
Thanks for the input. I found a few similar threads on some other forums and they used similar solutions.
Welding sheet metal is difficult for me but I think I have too much rust to ignore. I don't have the patience to let things cool and I get warped areas.
1946 Chevy Half Ton
You may want to check this repair piece out. It is on EBay for $64.
http://www.ebay.com/itm/1939-1946-C...77391354?vxp=mtr&hash=item4aafd28cfa
Harold
Harold
