1 members (Cosmo), 86 guests, and 0 robots.
Topics128,049
Posts1,055,680
#792827 10/27/2011 9:00 PM
I am thinking of purchasing a K51 Panel Truck. Unfortunately, the Seats are missing. Does anyone know where to get Seats? Reproductions, NOS, or Take outs are fine.
pb1 #792856 10/27/2011 10:25 PM
Is it a 4 x 4 panel truck ?
Tim
1951 3100 Chevrolet
bowtietim #792870 10/27/2011 11:00 PM
Yes it is. A 1.5 Ton Long Wheelbase Panel Truck. It has the Dual Rear Wheels.
Wolfen #792872 10/27/2011 11:05 PM
pb1 Offline
If it's the same as cletis pic below, then it's a 41-47(early) panel. Be very careful about the seats. The 1/2 ton seats arent the same. The easiest would probadly be a bench type, with back support frame- or possibly the 41-46 3/4 split suburban front seat. Be sure to check the installed seat height before buying anything. Steve
46 1 1/2 ton LWB Panel
pb1 #792899 10/28/2011 1:16 AM
A few posts have been deleted.
Communications, negotiations, and transactions between two individuals should take place via email or via Private Messaging.
Wolfen,
If nobody post information about a company that sells the part you are looking for, post a Want Ad in the Swap Meet and keep an eye on eBay and Craig's List.
Last edited by tclederman; 10/28/2011 10:58 AM. Reason: a few posts have been deleted
tclederman #792906 10/28/2011 1:33 AM
Cletis #792937 10/28/2011 2:50 AM
Cletis,thanks for the picture,that's cool.
Tim
1951 3100 Chevrolet
bowtietim #794081 11/01/2011 12:03 AM
In case this helps, I've been told, that the Seats are the same ones as found in a 1941-1946 Chevy Panel Truck.
Wolfen #794118 11/01/2011 2:22 AM
pb1 Offline
Once again, check the height. If your gas tank is under the seat riser- the 41-46 panel bucket seats will sit about 4" too high...
pb1 #794160 11/01/2011 4:40 AM
Take a look at this site.
Harold
http://www.brads41-46chevys.com/id6.html
Harold
Harold46 #794318 11/01/2011 8:23 PM
Thank you.
