9 members (MickeyP, Otto Skorzeny, sron48, KCMongo, Nick in Manitou, mick53, Gdads51, Jaison, 1 invisible),
100
Mod | | | Forums66 Topics128,050 Posts1,055,704 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 5 New Guy | | New Guy Joined: Sep 2011 Posts: 5 | I am thinking of purchasing a K51 Panel Truck. Unfortunately, the Seats are missing. Does anyone know where to get Seats? Reproductions, NOS, or Take outs are fine. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Is it a 4 x 4 panel truck ?
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2011 Posts: 5 New Guy | | New Guy Joined: Sep 2011 Posts: 5 | Yes it is. A 1.5 Ton Long Wheelbase Panel Truck. It has the Dual Rear Wheels.
| | | | | Joined: May 2010 Posts: 43 Shop Shark | | Shop Shark Joined: May 2010 Posts: 43 | If it's the same as cletis pic below, then it's a 41-47(early) panel. Be very careful about the seats. The 1/2 ton seats arent the same. The easiest would probadly be a bench type, with back support frame- or possibly the 41-46 3/4 split suburban front seat. Be sure to check the installed seat height before buying anything. Steve 46 1 1/2 ton LWB Panel
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A few posts have been deleted.
Communications, negotiations, and transactions between two individuals should take place via email or via Private Messaging.
Wolfen,
If nobody post information about a company that sells the part you are looking for, post a Want Ad in the Swap Meet and keep an eye on eBay and Craig's List.
Last edited by tclederman; 10/28/2011 10:58 AM. Reason: a few posts have been deleted
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Cletis,thanks for the picture,that's cool.
| | | | | Joined: Sep 2011 Posts: 5 New Guy | | New Guy Joined: Sep 2011 Posts: 5 | In case this helps, I've been told, that the Seats are the same ones as found in a 1941-1946 Chevy Panel Truck. | | | | | Joined: May 2010 Posts: 43 Shop Shark | | Shop Shark Joined: May 2010 Posts: 43 | Once again, check the height. If your gas tank is under the seat riser- the 41-46 panel bucket seats will sit about 4" too high... | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 |
Harold Is a restoration ever finished? | | | | | Joined: Sep 2011 Posts: 5 New Guy | | New Guy Joined: Sep 2011 Posts: 5 | | | |
