| | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79246 06/26/2007 6:09 PM | Joined: Sep 2006 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 19 | a friend of mine has a 1954 chevy pickup and he says that his engine is a 261cuin! i thought these engines were only fitted to the later 60's trucks. does anyone know if the 261 was fitted to the 1954 pick up?? thanks for any help Danny | | |
#79247 06/26/2007 7:28 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | limey dan,
If you search on "261" in this forum, you will find a lot of info about the 261.
In 1954, the 261 was an option on only large trucks (5000 series and larger). Someone (even a dealer) could have easily fitted a 261 to a 1954 1/2 ton truck.
Tim | | |
#79248 06/27/2007 12:28 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | When I 1st got my truck from my Dad, his mechanic who had experience with these trucks told me my truck had the 261. Even though I felt he was a guy who would know, he was wrong. As Tim said, do the search and you will find out. You can find casting numbers at inliners.org | | |
#79249 06/27/2007 12:41 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Correct me if I'm wrong (which I'm sure somebody would do) but don't the 261's have 2 little cast vertical bars....like captain's bars up under the intake/exhaust manifold? They sure would make it easier to ID a 261 than by shuffling through a handful of papers. This would eliminate the 235's and concentrate the numbers search to only 261's.
Dave | | |
#79251 06/27/2007 3:47 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No need to shuffle through papers. Here are the 261 casting codes. | | |
#79252 06/27/2007 6:19 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The "captain bars" are over the starter, not on the intake side. | | |
#79254 06/27/2007 11:45 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | My 1954 261 block has the captain bars on both sides also.It is out of a 1954 2 ton truck. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#79255 06/28/2007 3:42 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As stated above, the "captain's bars" are not a sure indicator of a 261, especially in 1954.
As stated in a Jim Carter Tech Tip:
"Watch for the "Captain's Bars!" The 261 has two pairs of parallel raised 3/4 inch long bars cast in the block. This is not seen on a 235 except 1954. One pair is above the starter and the second pair is at the top middle of the left side of the block very close to the head. See photos below. The one exception is the early 261 produced in 1954 to mid 1955. It has only one "Captain Bar" above the starter but keeps the pair on the left side."
The best identifiers are the casting numbers (linked above). | | |
#79256 06/28/2007 4:21 AM | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Thank You,TC. I've printed out that info.,,,i know a buncha people that'll want copies also. As usual,,youre the walking,talking shop manual!
Happy Truckin, Marty | | |
