1 members (JW51),
137
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 74 | I messed up. I did not keep track of the wiring that goes to the battery for charging from the generator. Thanks | | | | | Joined: Jul 2011 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 74 | New at this. That was a 1948 chev panel van. and it is a 12v system. Thanks | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | I assume you're asking about how to re-connect the wiring? There should be three wires attached to the generator. The larger-gauge wire (usually #12) attaches to the upper terminal on the generator housing and connects to the "ARM" terminal on the voltage regulator. A smaller wire, (#16) attaches to the lower terminal of the generator and attaches to the "Fld" terminal at the regulator. For best operation, a third wire should attach between the generator housing and the base of the regulator to provide a direct ground for the field cotrol circuit. It can be a #16 or smaller. The "Bat" terminal of the regulator should have a #12 or larger wire attached to the back of the ammeter, on the same terminal that provides voltage to the ignition switch, headlight switch, and the fuse panel. The wire on the other side of the ammeter should be attached to the battery cable terminal at the starter. It should also be a #12 or larger gauge. Jerry
