8 members (Gdads51, frogfarmer, Jon G, Hotrod Lincoln, gswbbc, Bill Hanlon, JoeDude, tclederman), 139 guests, and 3 robots.
Topics128,038
Posts1,055,536
Members48,425
#791650 10/24/2011 2:48 AM
On my 1939 JD pickup, the passenger door has an outside handle with a hole for a lock cylinder. It appears identical to the left door handle with the exception of the cylinder hole. I can find nothing in any of the catalogs. Does anyone know if the '39s could be had with a locking door handle? If so, what lock cylinder do I need to make the whole mess work?
Gary
I think you could only get them this way. You get used to it after a while *g*
1940 Chevy KC 1/2-Ton
Ex Hall Monitor
Ex Hall Monitor
To the best of my knowledge the locking handle was only on the passenger side. Keep an eye on ebay or maybe post on HAMB for a handle with the lock cylinder.
Ah, yes, I have "gotten it." I have owned the truck since about '62, and am entering my 3rd year of "restoration," such as it is. I have had the truck in Mexico, Canada, and from the Pacific to the Atlantic, and all under it's own power. It is...tired, and with reason.
But I also have gotten that this forum is by far the best for bits and pieces of information.
I do appreciate the responses, and will move forward, but with a different point of view.
Bruce,
As to the radiator shell problem, I, too, had to finally attack it with a dremel tool, and still shim it about 1/2 an inch. All is now well and good...at least for now.
Gary
