| | | Forums66 Topics128,060 Posts1,055,837 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | can i use a saginaw 3 spd from a 66 impala in my 51 chevy half ton. do i need to fab some shift linkage up? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy fosters51deluxe5, yes you can use the trans, it should bolt to the bellhousing, but it is longer than the original so you can't use your torque tube without extensive modification of both the driveshaft and the transmission. You could install an open drive rear axle, and have a driveshaft made to fit, hope that helps. | | |
