Hy fosters51deluxe5, yes you can use the trans, it should bolt to the bellhousing, but it is longer than the original so you can't use your torque tube without extensive modification of both the driveshaft and the transmission. You could install an open drive rear axle, and have a driveshaft made to fit, hope that helps.
