2 members (texczech, Peggy M), 100 guests, and 1 robot.
Topics128,136
Posts1,056,427
Members48,441
Hello!
I want to get the horn working on my '59 Apache, but here's what I have on the steering wheel...basically nothing (click on link below). Can anyone lay out for me exactly the parts I'll need, and maybe point me to a schematic of how things are set up on the steering wheel?
I found the horn wire socket under the dash, and the relay and horns are still there, so I'm not going to worry about that part of things now.
I'd appreciate any help anyone can give me.
Thanks...
Chris
http://i904.photobucket.com/albums/ac248/barsteel/100_0083.jpg
V
VEW Offline
V Offline
Chris,
There's a spring with a copper end that goes down in that hole. Also available is a kit that screws into your steering wheel. Your horn cap goes onto that.
I'm sure someone will advise of the part numbers.....I don't have them.
~ Victor
1957 3100 - moved on
