11 members (Eisenholtz, Gone, Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren, 1 invisible),
72
Mod | | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | Hey, bolters. Finally have my '46 two ton on the road and got the hang of double-clutch upshifting, BUT the downshifting is killing me! No matter what I try, I can't seem to downshift. Should I double clutch to downshift too? Any tips or hints would be great. Thanks, guys.
Adam
1946 2 Ton Flatbed
| | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Yes, double clutch going down. You need to clutch, take out of gear, rev. engine to match higher rpm of lower gear, clutch and put in gear. Not sure about the 2 speed rear ends, if you have one.
It's all about matching the engine speed. So listen carefully at the shift points as well as watching the speed at those points. It's also possible to shift without using the clutch. That's when you really know your truck. You are almost there! | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Just think before making a shift and take your time. You need both feet working together along with your shifting arm. | | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | Definitely. It is more crucial to double clutch downshifting than upshifting. | | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | Thanks, fellas. Going to put some practice in this weekend. I'll give an update as to how I'm progressing...
Adam
1946 2 Ton Flatbed
| | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | take youre time and pratice ,,gently,, the knack will come to those who wait,,
that may sound an odd saying, but when youve mastered it you will understand what it means
i grew up on old foden, trucks in the uk. old low revving ,,sloggin,, gardner engine,s with fodens own 12 speed DP box,s they were 4 on the stick with three seperate range,s the early one,s had the range,s on another gear stick that meant you had 2 sticks to work together
now that was driving ,,,
live or die do it with spanner in hand
