7 members (55shaker, TexasA&M48Truck, MickeyP, Ponchogl, Hotrod Lincoln, Nick in Manitou, 1 invisible), 126 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#771609 08/14/2011 11:40 PM
I removed my fuel pump on my 46 Chevy and after some cleaning and trying to get that one last spot I kept disassembling and realized I need new gaskets. Does anyone know where to get a gasket kit for a fuel pump on a 216? Or preferably the NAPA part number for the gaskets, or will I have to just buy another pump.
akguy34 #771654 08/15/2011 2:44 AM
It shouldn't be difficult to make if you are stuck. Sorry, I thought I read gasket as in pump to block gasket.
1951 1 Ton Completed
truckernix #771737 08/15/2011 12:22 PM
egge, kanter, jim carter, chevs of the 40's are a couple of places to start. It is getting to the point where you are kind of hard pressed to just go to a store and get parts for these trucks, you usually have to wait a bit.
brokenhead #771741 08/15/2011 1:01 PM
If you go to Napa you can probably buy a replacement fuel pump for less money that a rebuild kit will cost. If you are opening the pump to clean stuff out you should remove the check valves inside. You should also think about looking inside your fuel tank if you have lots of stuff in the fuel pump. Don
Does anyone have the Napa part number, the guys up here can't find the part in there computers.
akguy34 #787330 10/09/2011 5:08 PM
If no one responds you could try Napa online web site and ask them. I believe they have a "contact" feature. Then get your local guy to order it out.
Ed
Forty9 #787332 10/09/2011 5:09 PM
1 Offline
They are a stock item at Patrick's, Bowtiebits and Chevysoftheforties if you can't get any help locally. There are single and two stage vacuum pumps.
Normbc9
Wow, I wish I stocked up on glass fuel pumps 3 years ago! I bought mine at O'reilly for $25 then. Now you can't touch a kit for $40! The cheapest replacement I can find now is at RockAuto for $32.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
it doesn't cost any more, the money just isn't worth anything any more
brokenhead #790542 10/20/2011 2:46 PM
^ x2
Between Autozone and NAPA I haven't had any trouble finding gaskets for the 216 or any of its parts. The manager at NAPA even put in a good bit of time helping me find a suitable replacement gasket for my Innerline oil filter.
