3 members (klhansen, ronsway, 1 invisible),
165
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | @ schools of thought. MP90 I thought but was told to use ATF. Makes it shift better?? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There has been a lot of discussion on this. Some of the early models recommended 90 Gear oil. Most all now say use ATF. If it is a world class it is a must. I have put ATF in all mine for the last several years & it has worked good. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | My personal choice.....based on 14K miles on my S10 based 1986 NWC (brass synchro).72 OD T5.....all with 90w gear oil in my 54 truck. No evidence of metal in case at 3K, 6K and 10K. In my Camaro hybrid T5 behind a built 355 in my hot rod, also with a NWC (brass synchro) T5 I run (3K) Royal Purple SynchroMax with no metal in oil sample.
As Wrenchbender pointed out, the WC box with the synthetic synchro, requires an ATF weight lube. My personal experience has verified that a used S10 NWC T5 box in good condition, will function properly with either 90W OR ATF. However, I would suggest using a fortified ATF if you go that route.
The only downside I've noticed with the 90w is a little stiff shifting on mornings when the temperature is in the 40-50's before the engine has warmed up. As for the Camaro-based NWC T5.....it has been put through the wringer behind the 355 and has proven to be a whole lot more durable than I had imagined.
As for shifting better; I'd venture to say that aside from being a bit stiff in cooler weather the 90w would be great in a box behind a 6 cylinder. Behind a V8, using the nwc Camaro box I wouldn't hesitate to use a fortified ATF.
Hope this helps.
Dave
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Thanks guys. It is going behind a warmed up 350 | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Got more problems, going to the hi-po page | | |
