4 members (Wickedbass, Southerntruck, GRNHydra, Wally / Montana), 53 guests, and 2 robots.
Topics128,066
Posts1,055,876
Members48,428
#790198 10/19/2011 4:23 PM
See photo This was with my transmission mount parts and lines up with the mounting holes on the ball collar to transmission holes, but I don't see the purpose or how it installs?
Dave
www.fallenherosdreamride.org
all give some
MY SON GAVE ALL
The fallen hero's dream ride is a 1951 Chevrolet 3100 with original 216
In memory of LCpl Phillip Vinnedge USMC KIA 10/13/2010 Afghanistan
this part is a retainer for the bolts that go through it, flatten the tabs before installation and bend them back up against the bolt head to keep them from backing out, just a better lock washer...........
Mike B
Thanks. I'm curious why there is only one. Does it mount on the top or bottom? I guess that's why I only have 2 lockwashers. Also, two of the bolts were worn badly just below the head, not sure if they were top or bottom. photo of one worn, one not
Dave
all give some
MY SON GAVE ALL
I would replace the originals, they should still be available, and the bolts also, I know that a similar locking tab like that is used on exhaust bolts on the chevy 454s, I dont know if they are the same size as that one.
also I am not fimialar with the stuff you took that off of, so no help there. you might be able to find some at one of the chevy or gm dealership that would work, just take that one for a size comparison, good luck Mike B
By the way there should have been two of them if there are only four bolts, three if there are six bolts.....
Mike B
Unless you're interested in doing a 100% correct restoration, just eliminate that piece and substitute lock washers, or use a drop of blue LocTite to retain the bolts. If you opt for the LocTite, clean the bolts and the female threads thoroughly with spray brake cleaner or some other type of volatile solvent to be sure there's no oil on the threads. I'd use threadlocker if it was my project.
