3 members (Bill Hanlon, Patina 54, Guitplayer), 88 guests, and 2 robots.
Topics128,035
Posts1,055,441
Members48,422
#790189 10/19/2011 4:08 PM
I have a turn signal problem that doesn't seem to have been addressed previously. I have a 46 two-ton that came with a non-functioning set of turn signals. They were wired totally separate from the brake/tail light. I have installed new wiring and purchased a 7 wire turn signal unit and installed it. My wiring is as instructed except for the wire to the brake light switch, which I have not connected (since the turn signals are totally separate). The good news is that the lights light up as they should. The bad news is that they don't flash. Any ideas? Thanks for the help - I love these forums!
a 7 wire unit has to include the brake light circuit - read this carefully - rewire your unit as a 5 wire or set it up so you have "dual brake lights"
Riding in the Passing Lane
If the lights come on & dont flash you have a bad flasher or the wrong one.
1972 Chevy c10 Cheyenne Super
The 7 wire unit is not required to incorporate brake lights. That is a very handy feature of it but it can be wired to use separate lights for the signals and the brakes.
Wrenchbender has your answer.
