7 members (55shaker, dt235sd, Hanks custodian, NJC, 3B, Gdads51, 1 invisible),
211
Mod | | | Forums66 Topics128,086 Posts1,056,098 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Hello!
Decided to removed the old single exhaust on my '59 Apache in preparation for the installation of duals. Based on what I learned here, I decided to go with 2 1/2" ram's head manifolds.
First problem - The PO put the 283 heads on the 350 that's in my truck, so, no accessory holes, and I just discovered that the new manifolds I bought do NOT have the cast-in bracket on the manifold for the alternator bracket. Has anyone ever made a bracket and used the two front manifold bolts to hold it on?
2nd problem - the bolts in the middle of the manifold will NOT come loose. I've been tapping them with a hammer to try to break the rust loose, but no luck so far. I do NOT want to break the bolts in the head.
Any suggestions?
Thanks...
Chris | | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | Apply Kroyl, it absolutely works. I use it on guns, truck, anything that is stuck. http://www.kanolabs.com/ John | | |
