5 members (1955 1 Series, 3800GUY, Shade Baby, TooMany2count, Bluesky54), 131 guests, and 2 robots.
Topics128,110
Posts1,056,274
Members48,439
#789592 10/17/2011 7:44 PM
Hello!
Decided to removed the old single exhaust on my '59 Apache in preparation for the installation of duals. Based on what I learned here, I decided to go with 2 1/2" ram's head manifolds.
First problem - The PO put the 283 heads on the 350 that's in my truck, so, no accessory holes, and I just discovered that the new manifolds I bought do NOT have the cast-in bracket on the manifold for the alternator bracket. Has anyone ever made a bracket and used the two front manifold bolts to hold it on?
2nd problem - the bolts in the middle of the manifold will NOT come loose. I've been tapping them with a hammer to try to break the rust loose, but no luck so far. I do NOT want to break the bolts in the head.
Any suggestions?
Thanks...
Chris
Apply Kroyl, it absolutely works. I use it on guns, truck, anything that is stuck. http://www.kanolabs.com/
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
Chris;
x2 on the Kroil or a 50/50 mix of acetone & ATF. For the alternator bracket there are folks that sell well engineered pieces for not so crazy $$$. See these for example:
https://www.welderseries.com/blog/online-store/alternator-mount-kits/
http://www.waldenspeedshop.com/jitney.html
SimS
