8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 62 New Guy | | New Guy Joined: Aug 2011 Posts: 62 | Took everything down&out for new paint. Now that I'm almost done, I'm starting to look at the old wiring harness ('57 Chevy 4400). What have you guys done to Re-wire your vehicles?
Cleaning as best as possible?
A "simple man's plan" for a creating your own harness (e.g. visits to the local electronics store)?
Ordering a new harness is out of the question. I wish I could afford it, but have been doing a "Rat Restore" all around the truck for the same reason ;-P | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will have to clean it up & retape it as best you can. Trying to make up a new one will cost more then buying one. You would need about 50 different color/size spools of wire & several assortments of terms. What about one of the universal cheaper ones? They say they are good quality & instructions. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2011 Posts: 62 New Guy | | New Guy Joined: Aug 2011 Posts: 62 | How should I go about cleaning the plastic female terminals? :-S
All of it (99%) actually worked before I took it out... but in my mind looking at the whole haress on the ground it didn't look like too big of a project. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Speedway Motors has a "poor mans" harness for $150 that is high in quality. It's a basic 12 circuit item that is just right for old trucks that aren't all loaded with accessories. It includes electric wiper and alternator options along with all the normal stuff. All the wires are labeled every several inches as to where they go so even beginners can breeze through a rewire job. Once installed everything is protected by fuses or breakers. It's called "Mister Roadster" and is part# 910-64017. Beats the heck out of the $450 to $650 some others are getting.
Evan
