0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#789434 10/17/2011 3:11 AM
Took everything down&out for new paint. Now that I'm almost done, I'm starting to look at the old wiring harness ('57 Chevy 4400). What have you guys done to Re-wire your vehicles?
Cleaning as best as possible?
A "simple man's plan" for a creating your own harness (e.g. visits to the local electronics store)?
Ordering a new harness is out of the question. I wish I could afford it, but have been doing a "Rat Restore" all around the truck for the same reason ;-P
Riding in the Passing Lane
You will have to clean it up & retape it as best you can. Trying to make up a new one will cost more then buying one. You would need about 50 different color/size spools of wire & several assortments of terms. What about one of the universal cheaper ones? They say they are good quality & instructions.
1972 Chevy c10 Cheyenne Super
How should I go about cleaning the plastic female terminals? :-S
All of it (99%) actually worked before I took it out... but in my mind looking at the whole haress on the ground it didn't look like too big of a project.
I used this harness on my '59 from Classic Parts. Works great, easy to do, decent price.
http://www.classicparts.com/1955-59-Wiring-Harness-Generator/productinfo/52-027/
Speedway Motors has a "poor mans" harness for $150 that is high in quality. It's a basic 12 circuit item that is just right for old trucks that aren't all loaded with accessories. It includes electric wiper and alternator options along with all the normal stuff. All the wires are labeled every several inches as to where they go so even beginners can breeze through a rewire job. Once installed everything is protected by fuses or breakers. It's called "Mister Roadster" and is part# 910-64017. Beats the heck out of the $450 to $650 some others are getting.
Evan
