6 members (68ironhead, Oswald, DHedrick, 3B, Gdads51, 1 invisible), 74 guests, and 4 robots.
Topics128,151
Posts1,057,009
Members48,460
#789342 10/16/2011 10:48 PM
Could someone please tell me exactly where the cross member attaches that holds one end of the under-bed spare tire carrier on our trucks? Pictures are worth a $1000 bucks!!
Bought one at a swap meet and don't know where to attach the U-shaped steel bar that holds one end of the carrier. I know the other end hangs from a hook towards the rear of the truck.
Thanks for the help.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Book mark this site
....link....
His site is an education
What year?
There were two styles for 1/2 ton A-D trucks.
1950 1/2 ton. The carrier came off a '51.
Thanks Dads50 for the link to Dennys work. Great pics. My carrier looks like Woody's though.......not Denny's.
Thanks.
Chuck
1941 Chevy coupe
The one in the pictures that Gus linked us to is pre-'51 Spot. That would be what was
originally on your '50, 3104. In '51 and later models they went to the cross over style that
has the U-shaped hanger that you discribed. This type of carrier was used for many years
after its introduction.
Here is the layout for your '51, 3104:
http://www.pbase.com/dennygraham/image/138901806/large
DG
Denny G
Sandwich, IL
read this it has many pictures and will lead you to other posts on the same subject.
Thanks Denny for the info. I didn't know the carrier changed in '51. So, I guess I'll either have to jury rig this '51 carrier into my '50 or sell it and try to buy the correct one at the next swap meet. I'm leaning on trying to shoehorn it into my '50 as is. I'll work on it next weekend.
Thanks also to Gmoniz for the link. Good discussion there.
I still would appreciate someone taking and posting a pic of a '51 spare tire carrier properly mounted (original). It would help me see where to bolt/weld the cross member.
Thanks again.
Chuck
1941 Chevy coupe
Thanks again.
Dennys link above shows details on mounting the carrier
I have one reference photo you can look at
...pic...
Chevs of the 40's sells an aftermarket carrier
...link...
Quality looks suspect
originals are hard to find.
Dads50, Thanks so much for the links. I looked at all Dennys pics but his is of one that fits '47-'50. The one I bought at the swap meet came off a '51. I'm trying to adapt it to my '50.
I had no idea they changed from '50 to '51. The one from Chevies of the 40's is a bit pricy for me.
So.........I still am seeking a picture of a spare tire carrier on a 1951 1/2 ton if someone would be willing to post it/them.
Many thanks!
Chuck
1941 Chevy coupe
Thanks again.
...pic...
Another 1951 carrier, properly mounted
parts
Denny copied a sheet from the factory assembly manual in a post above for your year spare.
Here is another pic from the classic parts forum
....click...
...click...
I purchased an original off e bay a few years ago for my 50.
GMONIZ, thanks for the links. The picture of the blue truck is a good one but unfortunately does not show up close of how the support crossmember is attached.
Dads50, thanks for the link to that album. Jim did a super job of restoring his green truck and several of the pics during disassembly showed the support bar for the spare tire carrier. I saved them all to my computer and will use them for reference. I think it should be possible for me to use the '51 carrier on my '50 without too much adaptation.
Thanks everyone for your help in solving my problem. Now I've got something to work with next weekend.
Chuck
1941 Chevy coupe
