4 members (TexasA&M48Truck, Mike B, 1955 1 Series, baldeagle), 121 guests, and 2 robots.
Topics128,026
Posts1,055,409
Members48,422
#789083 10/15/2011 6:47 PM
Okay, just installed remanufactured Rochester B carb on my 54 3100. 235 c.i. with hydramatic trans. Started right up, but the throttle sticks when given gas, and I can only decrease the throttle by getting under the hood and moving the linkage manually. Don't want to road test it until I can control the throttle. Any ideas?
Disciple
Did you check/hook up the throttle return spring?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Yes, the throttle spring is attached. I figured out that the throttle linkage was rubbing on my manifold. A little bend made it work properly.
Disciple
Nice! I've forgotten to replace the spring before.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
