8 members (Gdads51, Rusty Rod, klhansen, 2-Ton, Bills54, Steelonsteel, stoveboltgator, dt235sd),
132
Mod | | | Forums66 Topics128,048 Posts1,055,539 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 7 New Guy | | New Guy Joined: May 2011 Posts: 7 | I am having an issue with my brake light.It will not work unless the tail light is on.I am sure it is something simple.I have installed a new wiring harness and have a good ground to my tailight.Also by the way my park lights no longetr work.I am wondering if I have something wrong on my switch?Thanks
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What year truck?
Do you have turn signals?
Stop lights and tail lights are separate circuits. Have you check the headlight switch to see if the stop lights are not on the terminal designated for the tail.
| | | | | Joined: May 2011 Posts: 7 New Guy | | New Guy Joined: May 2011 Posts: 7 | Hi,I found the problem!I had to do some rewiring on my headlight switch.Funny how a rear brakelight problem can be traced to the headlight switch.I have a 52 3600 and my Dad has a 51 car manual that we looked at.I had to move the main power going in the switch and the tail light wire to different circuits and it worked! | | |
