0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#788504 10/13/2011 2:21 PM
I have been told that I should use a 'leaded' gas additive since I am running unleaded gas in my '51 1/2 ton.
I have heard this before, but others have said the truck will run fine on regular unleaded gasoline.
Can someone fill me in what is the proper fuel to use in these older, 'pre-unleaded' fuel vehicles.
Git_Er_Dun #788545 10/13/2011 5:00 PM
i used reg. unleaded for years before i had the engine overhauled and no problems. also have a 1960 mga and use unleaded and i have had it since DEC. 1968 no problems.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
WE b OLD #788740 10/14/2011 8:04 AM
You only need to use lead additives if your cylinder head has not had hardened exhaust valve seats installed. This process is done by cutting a counterbore and pressing in a seat, then cutting for the valve. If your head has been in a machine shop in the last 20 years, its probably been done. If it is original, you take the chance of burning a valve on unleaded gas.
Git_Er_Dun #788758 10/14/2011 1:17 PM
For normal use you can run unleaded gasoline and will never have a problem. It has been discussed many times here.
don stocker #789050 10/15/2011 3:51 PM
Ex Hall Monitor
Ex Hall Monitor
What Don said. Engines made before lead was put in gas didn't have "hardened" seats.
Tiny #789067 10/15/2011 5:02 PM
Ditto on Don's & Tiny's posts.
A high compression engine from leaded-gas years would likely have problems with non-leaded gas.
This does not pertain to any of our stovebolt six engines under normal driving conditions.
http://www.vea.qc.ca/vea/articles/unleaded.htm
tclederman #789080 10/15/2011 6:32 PM
Ethanol may be another story. Right now, it's OK, but if the fed decides to increase the quanity of ethanol in gas, as been discussed by the administration, that may become a problem.
Have I got a story for you - I moonlite at a machine shop that is beside an auto repair shop. One of their customers had their car brought in on a rollback a few days ago. Car would not start, owner said he just gassed up and drove about 5 miles and car just died. They checked everything, found nothing wrong. They decided to check the fuel - and turns out it was about 50% ethanol!! The gas station said they had numerous complaints and referred all calls to their distributor for re-imbursement (as long as you had a receipt!!). Gas station said problem had been corrected.
tcox #789150 10/16/2011 12:01 AM
Leaded gas is WW2
