| | | Forums66 Topics128,052 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 55 | Hello, I have done some basic stuff to motors before but this is the first time I have ever tried to bring one back to life after sitting for 30 years.
I am running the oil pump off a drill in order to pump oil cut with kerosene through the motor. I took off the valve cover in order to observe the oil getting to the top of the motor. However I don't have any experience with this so I don't know if I am getting enough oil flow. There seems to be a slow drip from the rocker arms on the ends will this be enough.
Thanks for any help you can provide.
Eric | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | That feed is restricted, so it wouldn't be a torrent anyway. However: the steel like going to the rocker shaft fitting is frequently clogged, bent, flattened etc. Disconnect it and see if the volume changes. If it does, the shafts are dirty. If not, the line may need replacing. | | | | | Joined: Jul 2011 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 55 | Disconnecting the tube from the rocker shaft to check oil flow is a good idea. I will have to take a look at that. Thank you. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | There really isn't much oil that comes up there. It doesn't take much oil to keep everything happy. On really old cars, like Franklins, you had to manually oil the rockers, a little can go along way. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You probably won't get oil coming out of the little holes in the rockers until the motor is running. It sounds to me like you have normal flow. | | |
