6 members (Jon G, tclederman, 52Carl, dt235sd, ShopRag, Bill Hanlon), 88 guests, and 4 robots.
Topics128,262
Posts1,058,331
Members48,485
I have a 1957 chevy c30. its an 8 lug like a 3/4 ton truck but its the 1 ton. I have the rear axle. I'm missing the entire front axle. been looking and looking for a good one but no luck.
how ever... right up the road in a c40 truck with its complete drive train. can I bolt it all on and go. I realise it has the 5 lug rims and all but can I just remove and replace my remaining drive train and install the c40 stuff.
there is no such thing as a C30 or C40 in 57, the designation for a 55-59 3/4T is 3600 and the 1T is a 3800, as would be shown by the fender side emblems, and both 3600 and 3800 have 8 lugs with either 17.5 or 19.5 wheels depending on GVW .... the 5 lug wheels would be on a 1.5T [or larger], 4100, 4400 [or maybe 6100] - not as simple as "just remove and replace"
Riding in the Passing Lane
A lot of 3/4-1 ton stuff enterchanges but the 1 1/2 ton is a much bigger animalL. If it has 5 lugs in front it will be 10 lugs in the rear.
1972 Chevy c10 Cheyenne Super
yes, but to refer back to my origional question. will the 1.5 ton rear and front axle bolt in place of the 1 ton rear and front axle. leaf springs, shackles, shocks and all?
no, everything is different, check a shop manual and the resto pack for specs
where are you?I have a front axle,
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
southeastern Arizona
Moderated by  Dusty53
