Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Otto Skorzeny, 3B), 131 guests, and 5 robots.
Topics128,274
Posts1,058,436
Members48,490
#78872 06/16/2007 3:32 AM
I have the engine out of my 53 3100 trying to get it all cleaned up and ready to paint. I can not get the vent tube out,I saw 2 srews in front of the tube and behind the fuel pump.When I took the top screw out I thought I heard something fall to the oil pan,so guess I have to pull the oil pan and fish out what ever fell. What was it? Do I just need to use more force to get the vent tube out? THANKS
Popa Kents Body Shop
#78873 06/16/2007 3:36 AM
The screws were holding a sheet metal baffle that prevents splash oil from flooding the vent tube and dripping onto the ground. Yes, you'll need to drop the pan to retrieve it. The vent is a firm press fit, so just use a little more persuasion to dislodge it.
#78874 06/16/2007 4:37 AM
Thanks Hotrod
#78875 06/16/2007 8:57 PM
Tap on it with a rubber mallet and work it back and forth. It's a tight fit for sure but it will come loose.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
#78876 06/17/2007 4:50 PM
Once you get the tube out you may be able to use a magnet to retrive the baffle without removing the pan.
Floyd
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
