0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I found a donor '58 half-ton for my '59 project. I have some dents on the eyebrows of my '59 fenders. The '58 fenders are in bad shape behind the wheels but the eyebrows look ok. I'm not a body man or a welder, but was wondering if it would work for the dented area of the fenders to be cut out, and the same pattern non-dented area of the donor to be cut out and welded in. ?? Just thought I'd spring this topic to see what the experts have to say about it. Jerry | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if you're doing it yourself, swapping the rear part will be an easier learning experience - hiring it done the rear would be cheaper .... but if the dents aren't terribly creased, pounding them out would be first choice
Bill | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Thanks for sharing the input, Bill. I'm wondering how well the Harbor Freight body repair tool set would work for this. I have plenty of hammers! Jerry | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Here's links to similar repairs for some insight on the work involved... Eyebrow repairs Fender Patch Seminar | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | That's exactly what I had envisioned. Thanks! I'll try to hammer the shape back if I can find the right tools. If that fails, I'll go back to the original plan... I'd love to attend a patch seminar! Jerry | | |
