| | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78858 06/15/2007 11:04 PM | Joined: Oct 2006 Posts: 12 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 12 | I have a 41 GMC it is supposed to be stock but the valve cover says Chevrolet! How do I find out what engine I have? can I do it with I.D. numbers? Where do I cross reference the numbers I have? Thanks for any help anyone might have. | | |
#78859 06/16/2007 3:54 AM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | First off, a Chevrolet valve cover WILL NOT fit a GMC, so the engine's been swapped for the Chev motor, which is very common. Look for the casting numbers, should be on the passenger side of the motor around the fuel pump, that number should be easily found on this site or go over to inliners.org and search their engine numbers. | | |
#78860 06/17/2007 12:43 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There'll also be a seria; number stamped on a pad right behind the distributor, that will help narrow down the original application, along wiht the casting date that is located above the starter.
Bill Burmeister | | |
