3 members (tesa, Bill Hanlon, Gray_Ghost), 76 guests, and 0 robots.
Topics128,076
Posts1,055,925
Members48,430
#772582 08/18/2011 12:47 AM
After wiring my AD truck this spring, I created a visio schematic. I decided to create a generic version so others can use it as a starting point to document their work as well. I have saved the generic schematic in various formats. Please feel free to download and change the diagram as you see fit.
AutoCAD Interchange format
AutoCAD format
PDF format
Portable Network Graphic format
Scalable Vector Graphics format
Tagged Image format
Visio 2002 format
Visio 2007 format
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
di1953gmc #772659 08/18/2011 4:57 AM
That is a nice diagram.
Cletis #774056 08/22/2011 10:09 PM
Thank you very much for taking the time to do this. I'm rewiring the amp gauge in my 1949 now and I can hardly read the diagrams. With the color added it really helps. Thank you again. Steven
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
Thanks, I saved the PDF format and now I can load it on my IPad and have a nice diagram that I can zoom in on right in the truck with me.
1950 Chevrolet 3100 5 window
Original 216ci and SM420 4-speed
di1953gmc #789078 10/15/2011 6:12 PM
This is my first posting. I'm new to the forum usage.
I am also electrically challenged. I have a stock 52 chevy, 12 volt. Put in new gas gauge. Wire from sending unit goes to which post on gauge, one nearest to E or F on the face? Other wire to ignition, correct?
Mike in Sycamore, IL
look at your wiring diagram - see where there is a line labeled "dash panel" - the front and back of the truck [headlights/tail light] relate to the dash line, the wires go exactly as shown, left and right
also, if you don't have a manual, find it here, also separate wiring diagrams there
squeeze #789270 10/16/2011 3:15 PM
Mike -
I installed a new 12v gas gauge from The Truck Shop in my '54 this week. The gauge should be marked with a "+" for the lead to the ign sw and with an "S" for the lead to the sender. The "+" on my gauge is behind EMPTY and the "S" is behind FULL.
Sand the cluster housing behind the gas gauge to clean metal. The back of the gauge needs to ground to the housing.
- Lonnie
My '54 3104
LonnieC #789582 10/17/2011 6:58 PM
Thank You guys for the fast and concise answers. Will be great to have a gauge that does something!!
