4 members (farmallb, Gib70, Gdads51, Nick in Manitou), 132 guests, and 3 robots.
Topics128,088
Posts1,055,998
Members48,430
#7882 12/10/2003 5:06 AM
Junior Member
Junior Member
Ya stovebolters how are you doing,been a while since I have been here.I need your guys help with a 283 rear main seal change I did with the engine in truck pulled the pan and pulled out the top half of the seal.When I was tapping out the seal I scratched the shaft where the rear main seal sits,will a scratch on the crank hurt anything help. thanks for the help.
#7883 12/11/2003 8:30 PM
Junior Member
Junior Member
In a metal scratch its not the groove that's so bad but the metal heaped up next to the groove. I am not sure the best way to get rid of the heaped up part. Like anything it depends on how big I guess. I'm thinking of doing the same job. Let me know how it works
#7884 12/11/2003 8:41 PM
If you have already put it back together, I would leave it be. At the worst you'll wear out another seal. If you're lucky it will be okay.
If it's still apart, take some fine emery cloth and smooth the surface on the crank. You will probably need to work all the way around the crank, it's one of those jobs where there's no stopping point. I'd pull the spark plugs to make it easier to turn the engine.
Fred
52 3600
69 C-10
#7885 12/30/2003 2:12 AM
Junior Member
Junior Member
hey guys thanks for the response with the rear main seal I used emery cloth on the shaft.I put the new seal in the motor went in perfect then put the right gaskets back in put the pan on.It works perfect no leaks!!!So if you are going to try this on your engine good luck and take your time.
