4 members (Mr Crosswrench, RLB, klhansen, 1 invisible), 108 guests, and 3 robots.
Topics128,133
Posts1,056,395
Members48,441
#788193 10/12/2011 4:38 PM
7
7 Offline
How do you remove the steering wheel from a 65 chevy c10? It has the horn rim.
k10 Offline
There are 2 screws on the back of the wheel on the spokes. Remove those and the ring and cap will come off. Then undo nut in traditional manner.
Don't forget to disconnect the battery.......
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
7
7 Offline
Thanks I was looking for screws on the front of the steering wheel. Did not look on the back.
If they are factory, they are 1/4" hex head...a 1/4" nut driver works great. My melon is too large to see them from the back, so if you can't see them, it is hard to determine what head-type they are for removal.
7
7 Offline
Thanks that will help a lot. I am going to remove the steering wheel and column for painting.
k10 Offline
If you need to see something that you "can't get your head around", use you camera phone and take a picture. Works great under the dash also.
