1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#786947 10/07/2011 4:50 PM
I know the horn works because when I place screwdriver between the screws holding the inverted cup and plastic ring and the side of the inverted cup the horn blows. But the horn does not blow when the horn button is depressed. The horn will also blow while I am trying to install the horn button but stops when it bottoms out against the steerng wheel. Is there a spring or spacer between the horn button and steering wheel? I have been unable to locate pictures or litature assocated with the horn button assembly. Any help would be greatly appreciated. Thanks Redo
Redo #786981 10/07/2011 9:21 PM
There is an exploded view in the factory build book. Im at work, but I can bring it in Monday if noone else has helped on it. I can scan and send the page to you.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
jon1963 #786986 10/07/2011 10:15 PM
Thanks I would appreciate that very much, I look foward to receiving it. If you like you can email it to me at [email protected]. Thanks Joe - alais Redo
Redo #787932 10/11/2011 6:47 PM
Redo, I apologize, the last few days have been very hectic. I have the book laid out and will get the copy sent to you tomorrow.
jon1963 #788208 10/12/2011 5:40 PM
No need to apologize I have also been busy, this is the first time on computer since my last posting. I would appreciate any information you can send me. I think I maybe missing a part, but I don't know what it is. Thanks Redo
Redo #788507 10/13/2011 2:30 PM
Ok, got the scanned (1st time) and tried to send, let me know if they didnt make it and Ill tray again. Still trying to figure this scanner out. Im outa town til Sunday, so itll be Monday before I can check my mail.
jon1963 #788529 10/13/2011 3:52 PM
I was unable to locate the scanned document / picture. Did you send the scanned documents to my email - [email protected] - or is there a link in your posting?
Redo #790159 10/19/2011 2:16 PM
Ok, sending again this morning...lets hope this works
jon1963 #790191 10/19/2011 4:12 PM
I got it - I must have a problem under the steering wheel - Thanks for your help
Redo #790535 10/20/2011 2:30 PM
No problem, sorry it didnt get through the 1st time.
