Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Dakota Bob, John Clawson), 151 guests, and 5 robots.
Topics128,283
Posts1,058,505
Members48,490
The rings that were sent for my 56 235 from Hastings have a three piece oil control ring. The manual talks about a four ring set: a top rail, bottom rail, a spacer and a flex ring.
What Hastings sent only have three rings: two rails and a flex ring (zig zag metal ring). Has the design changed? I checked their application list and the part number is correct. Can someone explain the change?
I just changed the rings on my 56 235 and the oil ring is a 3 piece. It was a three piece in the rings that I took out and my kit from NAPA came with a three piece oil ring. Have you pulled a piston and removed rings yet to see what you had?
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
H Online: Content
There have been many changes in ring design since that manual was published, so its information is somewhat obsolete. Early oil rings were single-piece castings, which were later replaced by multi-piece steel rings. The oil ring setup with a spacer behind the expander was found to be an unnecessarily complicated design, and it was phased out. Just be sure to stagger the ends of all the pieces, and don't let the ends of the expander overlap as you're installing the scraper rails, and you'll be in good shape.
Thanks for the reply. I'll have other questions during this build.
Rick...
