2 members (moparguy, DadsFirstPickup), 75 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
#786715 10/06/2011 9:36 PM
I purchased a NAPCO installation guide for the AD NAPCO in 3/4 and 1 ton models. What surprised me is they use the stock leaf springs and make no relocation of them to a parallel configuration.
Doing research on non parallel leaf springs in trucks, it is quite common in 4x4. I have read where some said the springs had to be moved in parallel for the 4x4 conversion.
This not being the case as the installation guide shows, it seems if we could find a axle with correct width for the front of our one tons, and moved the spring perches, why could we not convert using modern axle, and transfer case and make a 4x4?
The installation guide shows the only holes to drill were for the mounting of the divorced transfer case. Can it be that simple??
I think it COULD be that simple, but my experience was different. I had to use a F**d front axle because of my t-case choice - had to do with driver's side output shaft. The axle I chose had the spring perch cast right into the pumpkin. That meant I pretty much had to use the springs that fit the axle - and they sit parallel to the frame.
Of course the AD frame is not parallel - so I had to fab up some mounts for the spring etc. etc. etc!
I think if I had to do it over again I would either choose a different t-case/axle combination OR put the body onto a newer 4x4 chassis.
Just my two cents!
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
How about using this to outboard the front shackle? Seems simple to do.
http://www.levonius.com/adam/wheeling/1tonbuild.htm
Look at the 3/8/08 pictures for the idea above.
Do you have a clearance issue with the springs and tires since they are further out in the front than before?
Any pictures of your setup??
Those mounts look slick! I ended up doing something sort of similar in the back, but in the front I had to do differently. I used some 4x4 square tubing and sort of built it up as I went. I left holes to access the shackle bolts and such.
I've got some pictures, but it has been a while since I have posted pics. . .I'll try soon.
Craig
CK
Here are those pics I said I'd try to get. These are the front and rear mounts for the front springs only. I did something completely different for the rear springs.
Like I said the front mounts are 4x4 square tubing and the rear are 8" channel with a gusset. I put the shackle in the front - reason being I have read that there is a kit to change Jeeps to a front shackle set-up and the 4x4 world has done that for some reason.
http://i605.photobucket.com/albums/...with%20Dodge%20dually%20bed/IMG_0954.jpg
http://i605.photobucket.com/albums/...with%20Dodge%20dually%20bed/IMG_0953.jpg
http://i605.photobucket.com/albums/...with%20Dodge%20dually%20bed/IMG_0951.jpg
http://i605.photobucket.com/albums/...with%20Dodge%20dually%20bed/IMG_0952.jpg
http://i605.photobucket.com/albums/...with%20Dodge%20dually%20bed/IMG_0955.jpg
http://i605.photobucket.com/albums/...with%20Dodge%20dually%20bed/IMG_2600.jpg
http://i605.photobucket.com/albums/...with%20Dodge%20dually%20bed/IMG_2587.jpg
The last links show a mock-up of my '50 with the dodge dually bed on it. You can see the way I mounted the front axle dictated the height of the truck. A little more lift than I wanted, but it'll look cool anyway.
Craig
CK
Looks Good. Thanks for the pictures. How wide is the front axle? What axle model did you use?
The axle is off of a 1979 F**d F-250, but I wouldn't recommend using it because of the differential-mounted spring perch. It is *approximately* 70" from mounting flange to mounting flange. I would, if I had it all to do over again, pick a t-case with Passenger side output and then a GM axle with the passenger side pumpkin. Then it would be a simple matter of welding on the spring perches and you could use stock leaf springs on the AD chevy!
Just my thoughts. Hindsight really IS 20/20!
Craig
CK
Moderated by  Dusty53
