Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (TexasFarmTruck, crenwelge, Mike1933, tclederman), 227 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#7876 04/11/2005 3:16 PM
Is it "doable" to replace the canister oil filter with a remote spin on filter without modifying my 253 to full filtering? I'd just like to have a little more updated filter and the plumbing to the pressure gauge could be shorter and not stressed by engine movement. Would there be a pressure drop? Just thinkin'.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#7877 04/11/2005 3:39 PM
If you have the bypass filter canister, its fittings are too small to use as a full-flow filter. You need to replace it.
Fred
52 3600
69 C-10
#7878 04/14/2005 3:18 AM
Apprentice
Apprentice
I just put in an Amsoil remote bypass filter mount. Put it in the same place the regular canister filter goes on a 235. Used oil lines similar in size to the canister filter. Now I have a spin on filter, bypass to boot...
#7879 04/14/2005 5:53 AM
Ted,
Can you link a picture of your smart sounding setup? It would help some of us mechanically challenged folks to see a visual! :p
Jim Karras
Orange, CA
'59 Chevy Apache 32 Stepside Pickup
E-mail: [email protected]
Internet: www.59apache.com
#7880 04/14/2005 8:29 AM
If you are going to adapt a standard spin on oil filter to bypass use you need to provide about a 1/8" restriction to the return oil line to keep the oil pressure to the bearings high enough. The bypass filter is designed to only filter about a tenth of the oil flow through the pump. Other than that there should be no problems.
Paint & Body Shop moderator
#7881 04/14/2005 4:48 PM
I went with the Amsoil bypass unit as well. Works great. The hole in the spin on adapter is smaller than 1/8", it's more like a pinhole. It flows about 1 quart a minute at idle and I show 25 lbs. of pressure. It has a 3/4" thread so the replacement filter is a little big.I hard plumbed mine as well to eliminate hoses.No place to post a pic. but I can e-mail one to anybody that's interested.
Curt B.
You Tube
