| | | Forums66 Topics128,022 Posts1,055,382 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | I'm installing a 292 in my '53 3/4 ton. So far a fun project. Someone may be able to save me a lot of time by giving advise on alternator bracket. I need to know which bracket to use and where is the best place to mount it. I want to be able to eventually mount a power steering pump, but not right now. I would like to use a basic GM 1 wire alternator. Thanks much
jl
'53 chevy 3/4 ton
| | | | | Joined: Jun 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 85 | The L6 uses 2 alternator brackets: Lower (2) bolts into left side of block and mounts 5" or 6" (3/8"?) long bolt (going fore & aft) for alternator to pivot on. Upper bracket is curved approx 6" stand off, bolts onto front of head thru one of the water pump bolt holes and secures upper 1/2" alternator bolt at right fan belt tension. As far as the 292 P/S option, the power steering bracket bolts onto the head and sides of the block, the lower part has a slotted bracket for the upper alternator stand off. 292 P/S brackets are unique and rare. The Armstrong version alternator brackets are a lot more common and should be an easy junk yard find. I think 250s and 292s are the same in this respect, but I never ran a 250. Also I've only ever run the stock delcotrons w/ ext regulator, not sure if the "one wire" has the same dimensions.
Every 25 years I like to rebuild that 292 just for GP
