5 members (J Lucas, Brian Moore, Pete1946, Otto Skorzeny, Hotrod Lincoln), 124 guests, and 3 robots.
Topics128,072
Posts1,055,903
Members48,429
#78725 06/12/2007 9:35 PM
My front top shock mount is broken, it is a large pin rivited to the frame the shock fits on the pin, a stud protrudes from the pin, a nut and washer screw onto the stud to hold the shock in place. the stud on my mount is broken off, I was planing on grinding flush center punching, drilling and tapping to insert a new stud. does this sound exceptable or is there a better solution.
thanks
#78726 06/12/2007 10:43 PM
skip the new stud, you won't find it [unless it comes with the shocks], just use an appropriate sized grade 8 bolt
#78727 06/13/2007 5:24 PM
Got it. Thanks Bill
