Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (41 chev), 120 guests, and 2 robots.
Topics128,275
Posts1,058,572
Members48,492
Ive asked this question before and got a reply, thanks again ,so please excuse the redundancy but here is a reference that goes against the advice given.http://www.speedprint.com/deves50/doc/enginetiming.pdf
In my shop manual there is not a clear pic of the timing marks. So do the cam gear crank gear timing marks butt up next to each other >**<, apart from each other *< >*, or as in the above reference both marks at the 10 oclock position *< *< ???
Confused,
Rick......
The crank gear turns twice for every revolution of the cam. When you assemble the engine, the marks will go together. The drawing you are looking at is on the top dead center firing point I believe. Both will line up the same but I think that it is easier to spot that the marks are in the correct position when they are right together.
