8 members (1955 1 Series, klhansen, John Dlugos, Bill Hanlon, Gray_Ghost, Otto Skorzeny, 2 invisible), 219 guests, and 2 robots.
Topics128,101
Posts1,056,179
Members48,436
When I put a 261 in my 39 1/2 ton I also upgraded to a alternator. The belts scream at me when I give it gas. If I drive like an old lady it does not make a noise. I put on a new belt and the belt is tight. The alternator is new but I did not change any pulleys. What have I over looked? The belt noise is driving me nuts.
Scott
Try fitting a larger-diameter pulley to the alternator, if you can find one. Sometimes the belt contact area around the pulley isn't sufficient for the belt to get enough traction. If the crankshaft pulley is very large in relation to the alternator pulley, it might be trying to drive the armature too fast. A glazed belt surface is another possibility, if the squeal has been going on for some time.
How much of the belt is wrapped around the alternator pulley? If you install a longer belt and a longer adjuster bracket, there will be more belt wrapped around the pulley, which translates to more traction.
Had the same problem on my truck after starting from cold right from when I bought it.
I checked all the usual stuff, belt not bottoming in any of the pulley vees etc.
I could only get rid of it by running the belt very tight, wasn't happy with this as I didn't think the water pump or alternator bearings would last. I changed to this twin vee belt setup and that cured the problem straight away. perhaps you could get twin belt pulleys for your straight six if all else fails.
Stuart.
Finding a 2-belt crankshaft damper for a 235/261 engine is going to be a challenge. You'd also need a water pump with a second pulley groove to take that approach to solving the problem.
Scott, the 261 may have a wider belt than the alt. pulley. If you have the generator look at the width of the pulley. I think you can just swap the pulley.
Tommy
59 apache 1/2t
261 short stepside
1 Offline
It sounds to me like a bearing needs to be re-greased or has gone out on one of the pulleys which makes it squeal. You can buy bearings at your local Tractor Supply or auto supply store. Good luck, and let us know what happens!
Jim Carter sells the wide pulley for the alt.I put one on mine.
Pete
Mine were OK until I painted the pulleys,then the screeching started.
I scuffed up the contact area where the belts go with a Scotchbrite pad,problem sorted......
More pix on Flickr.
A little belt dressing would help.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Do all the pullys line up? is the altinator off?
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
