| | | Forums66 Topics128,099 Posts1,056,508 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 29 | I purchased a NAPCO installation guide for the AD NAPCO in 3/4 and 1 ton models. What surprised me is they use the stock leaf springs and make no relocation of them to a parallel configuration.
Doing research on non parallel leaf springs in trucks, it is quite common in 4x4. I have read where some said the springs had to be moved in parallel for the 4x4 conversion.
This not being the case as the installation guide shows, it seems if we could find a axle with correct width for the front of our one tons, and moved the spring perches, why could we not convert using modern axle, and transfer case and make a 4x4?
The installation guide shows the only holes to drill were for the mounting of the divorced transfer case. Can it be that simple??
| | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I think it COULD be that simple, but my experience was different. I had to use a F**d front axle because of my t-case choice - had to do with driver's side output shaft. The axle I chose had the spring perch cast right into the pumpkin. That meant I pretty much had to use the springs that fit the axle - and they sit parallel to the frame.
Of course the AD frame is not parallel - so I had to fab up some mounts for the spring etc. etc. etc!
I think if I had to do it over again I would either choose a different t-case/axle combination OR put the body onto a newer 4x4 chassis.
Just my two cents!
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Aug 2007 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 29 | How about using this to outboard the front shackle? Seems simple to do. http://www.levonius.com/adam/wheeling/1tonbuild.htmLook at the 3/8/08 pictures for the idea above. Do you have a clearance issue with the springs and tires since they are further out in the front than before? Any pictures of your setup??
| | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | Those mounts look slick! I ended up doing something sort of similar in the back, but in the front I had to do differently. I used some 4x4 square tubing and sort of built it up as I went. I left holes to access the shackle bolts and such.
I've got some pictures, but it has been a while since I have posted pics. . .I'll try soon.
Craig
CK
| | | | | Joined: Aug 2007 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 29 | Looks Good. Thanks for the pictures. How wide is the front axle? What axle model did you use?
| | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | The axle is off of a 1979 F**d F-250, but I wouldn't recommend using it because of the differential-mounted spring perch. It is *approximately* 70" from mounting flange to mounting flange. I would, if I had it all to do over again, pick a t-case with Passenger side output and then a GM axle with the passenger side pumpkin. Then it would be a simple matter of welding on the spring perches and you could use stock leaf springs on the AD chevy!
Just my thoughts. Hindsight really IS 20/20!
Craig
CK
