2 members (KEVINSKI, crenwelge), 108 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
#786344 10/05/2011 4:59 PM
I have a 1951 Chevy 3604 (3/4 ton) truck. Does anyone know how much gear oil I will need to purchase in order to change it out? I don't have anything big enough to measure it with if I were to drain it now, that way I can pick up the oil and a new gasket all at the same time. Thanks in advance, Jeff.
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
Thank you so much Cavebull, I have the 1951 shop manual but did not see that in there. Thanks again!
Another question to hijack the topic. I just got my issue of Skinned Knuckles and it has an article on the proper trans and diff lube. Basically that new lubes are bad for brass and bronze bushings. Is this a concern for our stovebolts? Curious what gear oil others are using. Thanks.
If you are concerned about this, go to some place like agri-supply and get a bucket of 90wt gl1. many of the gear oils today are gl5, which is the rating that may cause problems with brass/bronze.
This is what I do. I have a number of antique tractors that I run 140wt gl1 gear lube.
Kurt
Tractor Supply has GL1 90w gear oil, last time I was there it was labeled as Ford Tractor Gear Oil. You could also use a non detergent 40w or 50w motor oil. 90w gear oil and 50w motor oil are the same viscosities.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
