1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Rewired mt 53/3600 last Nov. and everything was really good. suddenly my stop lights are not working. Every thing else is good, flashers, turn signels. could it be where the two posts are going to the back or bad sockets. Bulbs look good, but I'll replace them. any ideas out there that might help. Have goten some great help in the past, Bolters are really a bunch of cool people. Paul | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | first check would be the stop light switch under the floor, wire might have come off, activating arm might have broken, or switch could have quit - an ohm meter would be useful
Bill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Depending on how you rewired it there may be a separate fuse for the stop light.
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I agree with 'Squeeze'. If you have the hydraulic type brake light switch, look there first. I have read that they are under engineered and don't have the current capabilities that they should. I replaced several before going to a "Lokar's mechanicial type.
| | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | Different truck but worth a thought, on my 55, the right rear brake light is wired through the signal light switch in the column. Right rear and it is a white wire.
1955 Chevy 3100
