1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#786654 10/06/2011 4:56 PM
Two openings on one end. Does it matter if the open ends are at the top or bottom?
~Jim
Huh?? There are two tubes in the 'bottom' of the tank. One tube is longer (inside tank) than the other. The short one goes to the radiator cap via hose. The longer one is the tank dump line. We run a hose from the taller one to under the frontend area somewhere. When fluid starts to fill the tank up it will rise till it reaches the top of the taller tube. It then is dumped overboard.
How do you know which tube is the long one?
~Jim
Unscrew the cap on top and look down into the cyclinder or resevior. One tube will be several inches longer or taller or the end will be closer to the top of the resevior than the other. If the resevior has no cap to look into, the use a small stiff wire with a short hook on the end. Run the wire up from the bottom. Measure the stiff wire when it exits the tubes at their top. One will be several inches longer than the other.
"use a small stiff wire with a short hook on the end."
Now that's pure genius and the kind of stuff necessary when building a modified Bolt.
~Jim
