1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 65 | I have a stock 36 I'm working on but would like to drive comfortably at about 60 mph when finished. Would rather not change engine, tranny and rearend if possible. Been researching 2 speed overdrive, or a full radical chassis swap (toyota). Any suggestions | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Deve's Antique Chevy site has info on a Borg-Warner 3 speed OD. You will need to change rear end. | | | | | Joined: Apr 2010 Posts: 244 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 244 | If you are not changing the engine, trans, or rear end,.... you'll need some reallllly big back tires! | | | | | Joined: Mar 2006 Posts: 143 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 143 | Al, Please give me a call (544-4564) I'm in Missoula and know a couple of people here with 36's. Glenn | | |
