4 members (Stovebolt48, Steelonsteel, Bill Hanlon, lumbersawyer), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#784689 09/29/2011 3:46 PM
what is the best way to protect the fuel system truck will be shut doun for winter. thanks
Give the gas tank a healthy dose of SeaFoam or Sta-Bil additive, and use "fogging oil" into the intake which can be purchased at most outboard motor dealer parts departments. It doesn't hurt to cover the intake and exhaust openings to keep critters like squirrels or mice out, and atmospheric moisture transfer into the engine at a minimum.
I see you're in the same area as me. I wait to top off the tank in November and add sta-bil. By waiting, we are no longer pumping the summer gas formula - I have no proof but I think winter gas doesn't have as much ethanol. In any case it has worked for me.
Winter gas still has 10% Ethanol. The difference is that the oil companies put Butane in their blends to help cars start easier. I see you are in the Chicago area, they have stiffer rules on the Vapor Pressuse regulations versus what we do down state. Basically, your winter blend is what we run during the summer down here. So, I wouldn't be afraid of topping off the tank. I used to delivey gasoline and ethanol all over the midwest, I've been out of the game for a few years, but I'm sure it hasn't changed.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog, thanks for the info on the Ethanol. It seems I have less trouble with winter gas, but from what you say it may well be my hopeful imagination.
